named queue stops working?
Hello, I've got a problem using named queues. I've wrote a program for a Measurement set-up, which is installed on a ferry to collect environmental data along the route between the home- and the destination port over a long period. In automatic mode the set-up is controlled by the ships GPS-position. If it leaves an defined area around the port, a calibration of some instruments is performed. After a succesfully ended calibration a "water-measurement"-mode starts in a timed loop (period 1 minute) till the ship reaches a specified latitude to perform some "air-measurments" and then go back to "water-measurement"-mode again till it reaches a defined area around the destination port and so on. In "water-measurement"-mode two readings have to be delayed for 2 minutes, to compensate the time, the water needs to flow from an outer sensor to the set-up. I thougt it was a good idea to use a named queue for each reading to delay it for two periods of the timed loop. A third named queue collects error informations around the programm. This error information is queued out, displayed and stored in a file in a separate loop. The program works fine at the first journey. At the run back only calibration and air-measurements are stored. I've got neither water nor error information. My next step was adding an additional named queue to collect status information about the programm parts which have passed through and additional every five minutes the actual GPS-position. Now all informations from sources, which are including a queue, is ending already about 20 hours past program start. About 45 minutes after truncation of water measurements, errorlog and infolog, the air measurements again are performed correctly. Before installation on board, we tested the set-up whith a simulated GPS-signal. In these tests we had accelerate time for a journey. Whith 60 minutes for one run between the ports we performed multiple runs without any problem. So I guess, there is a problem caused by my usage of queues. I tested my DataDelay.vi in a loop and got some strange results after I forgot to stop my test. It seems that labview is consuming an increasing amount of CPU-time after a high number of loop cycles. In the attachment I tried to speed up the effect by using 3 of these VIs in a loop. On my PC after about one hour the labview part of the CPU-time reaches nearly 100%. This may not be related to the problem at the ship, because the conditions are too different, but I don't understand it. My next trial will be to replace the queues for data delay by shift registers, "build array" and "delete from array". Since the set-up is installed at the ferry, it it costly and time-consuming to get access. I have to ride about 150 km to the port at tuesday evening to get some hours around midnight to make changes. Please excuse my english. I hope, someone can give me some hints to understand and solve the problem. Ha-Jo
Message 1 of 12
(4,996 Views)
Sorry, I've forgotten to attach the excample Ha-Jo
Message 2 of 12
(4,988 Views)
I took a very quick look at it and I am a little confused.  Why do you obtain the queue twice in the same subVI?  In the delay case you have the reference already but you obtain it again.
I wonder if your issue is that you are basically leaking Queue references.  You would have obtained a reference an lot of times after hours of operation.
Message 3 of 12
(4,981 Views)
Sorry again, seems that I attached the wrong VI. My login was timed out and Iwas a little bit confused. I had send the vi to a colleque, and I think he was playing a little bit around with it. Here comes the original excample. Ha-Jo
Message 4 of 12
(4,978 Views)
Wiring the queue references rather than repeatedly calling Obtain Queue in the DataDelay.vi speeds it up substantially. I am using LV 8.2 so I cannot easily give you a LV 7.1 version. I have attached an image of the Delay Case. By moving the Data valid indicator outside the case I have eliminated the local variables. This probably speeds things up also.
Lynn
Message 5 of 12
(4,967 Views)
Sorry, sorry, sorry
can't get rid of the wrong attachment. Now I renamed it and tried again. Thank you for the hint with the location of the data valid indicator, I will change it. The rest of my original VI, I think, isn't so much different from Your suggestion.
But I think, the main part of my problem isn't speed. In the original program the Datadelay.vi runs inside a timed loop with a period of one minute for a long time. After more than 20 hours of operation it seems, that the Data valid indicator turns false, preventing the rest of that vi to calculate and store data. In addition all my attempts to get infos about the state of the program or errors, where I used other named queues seems to truncate at the same time.
Ha-Jo
Message 6 of 12
(4,957 Views)
On Jul 13, 12:40 pm, Ha-Jo <x...@no.email> wrote:
> Hello,
> Ha-Jo
It seems like there is a memory leak due to queue not being emptied or
initialized. make sure that you initialize the queue first, use it in
the loop and delete the queue before quitting the program. If
synchronization is not important, try using shift registers or global
variables. hope it helps.
Message 7 of 12
(4,954 Views)
I wonder if your problem has to do with memory allocation? The queues keep growing in your application. Arrays will require memory re-allocation if they increase in size and I suspect that queues do also. Can you predict how much data will be collected over the length of your run? Or at least determine an upper limit on the amount of data? If so, create the named queue with a maximum size greater than or equal to the largest amount of data you need to collect. If the queues preallocate memory for a specified maximum length, then this would avoid the re-allocation issue. The help file does not specify how the queue handles its dataspace memory.
If you switch to arrays as you mentioned in a earlier posting, use Initialize array outside the loop with the size large enough for all your data and use Replace array subset inside the loop. Never use Build Array or Autoindexing on array which can get large or you will likely have memory problems.
Another option might be to only save a small amount of data in memory, write it to a file, then collect the next set of data. After the run is finished calculate the results from the data saved in the file(s). This also prevents loss of data if the computer loses power or the freezes.
Lynn
Message 8 of 12
(4,947 Views)
Thank you, unfortunately I missed to check the task manager to get some information about the state of the PC before I exit the program at my last visit on board the ship. I will overtake it when I visit the ship again next Tuesday night. Because the data delay is called every minute during the measurements, I will replace it by shift registers. I hope this helps me to get stable readings for some consecutive journeys. Now I will go offline till Sunday evening (it's already 9:47 PM here in Germany and I have to go to my hometown this weekend) Thank You all again Ha-Jo
Message 9 of 12
(4,940 Views)
Thank you Lynn, I didn't specify the length of the queues, but each of the two delay lines actually is holding only two doubles and all calculated values are written to a file on harddisk and additional to an USB-stick (for a convenient access) at the end of each cycle of the timed loop. The queues for my logs are also examined very often in a separate loop and each time, there is an element in it, it will be dequeued and written to disk (exceptly the errorLog, which is additional displayed on screen, but it doesn't containe much entries), so I didn't expect any memory problems. I will rethink my planed solution including the shift registers and the build array function to avoid calling the memory manager. I think, it's possible to build something like an fixed array and rotating pointers for access, but it has to wait at least till Sunday evening. Thank you all again Ha-Jo
Message 10 of 12
(4,935 Views)
