03-02-2018 09:03 AM
can anyone help me about this error.camera working perfect when i connect with only my pc but when i connect with myrio and then communicate with myrio over wifi then it give following error
imaqdx 0xBFFF8004
am using
03-05-2018 08:54 AM
Hi there!
What software do you have installed on the MyRIO? To use your camera with the MyRIO, you need to make sure to install IMAQdx. It also looks like the camera you are using is a USB 2.0 camera that is UVC compliant. When you install software on the MyRIO, make sure to also install USB Webcam Support.
-Jordan
03-05-2018 01:31 PM
Thanks for your kind reply i upgrade the all software related to myrio 2014 to 2017.but it's still not worked.again same error ocurred.
03-05-2018 02:06 PM
Have you tried formatting the MyRIO?
-Jordan
03-05-2018 11:08 PM
yes. i tried 5,6 times.
