myRIO Button-LED program not working on second run
I recently started working with the myRIO and am trying to run basic LabVIEW codes on it, to get a hang of it. I made the following LabVIEW code and was able to run it successfully, but after closing the .vi file and reopening it, it gave me an error- "The current personality or target does not support this VI. Switch to another personality or change the current target." for the LED and Button.
Does someone know what I may be missing or doing wrong? I am a beginner in working with both myRIO and LabVIEW.
Any help is appreciated, thank you!
(2,645 Views)
Hi rsaini7,
Did you open the VI from the project you created for your myRIO? I believe you will get that error if you open a VI without the project.
Best,
David F.
Applications Engineering
www.ni.com/support
(2,607 Views)
