my program doesn't graph
hey
I'm trying to have continuous acquisition from the Daq and as its getting coordinates, its supposed to be graphing. I'm not been able to graph any of the coordinates that are acquired.
Any help would be appreciated
Message 1 of 49
(5,274 Views)
Try it without resetting the Build XY Graph each time you call it.
I think this was mentioned before in one of your other posts.
Message 2 of 49
(5,264 Views)
i don't have the reset input connected. How is it resetting?
Message 3 of 49
(5,255 Views)
Right click on it and select properties. See the 'Clear Data on each call'? Reset true is the default.
Message 4 of 49
(5,251 Views)
I tried that now and it still doesn't graph. Also, for the first execution it runs perfect but for the second execution the daq gets an error saying something about the buffer size being too small and there isn't any samples left. Does that have anything to do with it?
Message 5 of 49
(5,244 Views)
Yes, it is very difficult to graph samples if they are not available. 😄
Message 6 of 49
(5,223 Views)
On the upside, they don't take up much memory.  🙂
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 7 of 49
(5,210 Views)
what do you mean Matt?
Message 8 of 49
(5,171 Views)
It's called a joke.
Try switching from continuous sampling to N Samples. You will often get the error when your processing time is lengthy and you cannot flush the DAQ buffer fast enough.
Message 9 of 49
(5,162 Views)
Hey altenback
The audio samples that I have to graph are confidential and I'm not allowed to release them. If you don't mind just adding in random corridantes generator to do the job that would be great.
thanks
Moe
Message 10 of 49
(5,151 Views)
