my labview cursor change to PLUS ( ) sign how to reset it
Hello
My labview cursor change to + sign and I cant select my Locked controls.. How can I canget to normal cursor...
Looking forward to your reply.
tejas
(3,974 Views)
Hit the Tab key.  It might work...
Jim
(3,961 Views)
Hi Tejas,
Please go to View --> Tool Palette
Check if the „Automatic Tool Selection“ is activated (green LED). Then you get your normal cursor back.
Tab Key differentiation:
„Automatic Tool Selection“ was activated at first:
If you change your tool / cursor mode and then hit the tab key the „Automatic Tool Selection“ will be activated again.
Automatic Tool Selection“ was not activated at first:
If you change your tool / cursor mode and then hit the tab key you will switch to the different tools / cursor modes
Regards
Carina
(3,918 Views)
Another way to bring up the tools palette is to hold 'SHIFT' whilst right-clicking with the mouse.  This works in the same way as you'd normally bring up the functions palette.
The 'Automatic Tool Selection' button is the longest/biggest one at the top of the palette (at least it is on my LV version).
Never say "Oops." Always say "Ah, interesting!"
(3,913 Views)
