mutiple data aquisition
i have a plant and my input is 4 analog in and my output is 4 analog out
can i just put 8 daq assistant inside my vi to manage my input and output?
or is there a more efficient way of managing my data?
(2,608 Views)
It'd be a lot better if you used one assitant for all 4 inputs and one for all 4 outputs.
(2,578 Views)
Hello Leongchuan,
Dennis is right. You only need to have one assistant on the block diagram for all your channels. When you are done with the first channel, there is an "Add" button that you can click on to add other channels. See the attached image for the location of the "Add" button.
Good luck...
Serges L.
(2,574 Views)
