multisim / Labview
Hello all
I'm a bit annoyed because I can not solve my problem, let me explain:
must be able to send a sine wave, I simulate in labview (attachment) in the first time, the input of a transformer assembly as real Multisim software.
This assembly is composed of resistors, capacitors and inductance at the primary and secondary, we need to change the values ​​of these componentsvia the labview interface (so you need to communicate between labview andMultisim for values) and finally after doing this must recover the output signal of the assembly and send it in order to make labview harmonic analysis tothat already.
I hope there will be someone who can help me in my research
thank you very much
cordially
(2,693 Views)
Hi Sherifalami,
In fact you can use VIs with Multisim, adding an instrument to a circuit.
To create theses instruments, you can go to the NI Multisim help "Creating a LabVIEW Instrument".
You can find examples from : "C:\Documents and Settings\All Users\Documents\National Instruments\Circuit Design Suite 11.0\samples\LabVIEW Instruments..."
(2,664 Views)
