multiple xy graph point by point
I would like to plot multiple trace xy graphs point by point. If I plot one trace, it does show up point by point, but plotting multiple traces, they traces show up one after another and not point and point. Attached is my code. Any help would be appreciated.
-Tim
(3,792 Views)
Here is updated code that demonstrates what I described above.
-Tim
(3,786 Views)
Accepted by topic author timothy123
That's because you use 'Replace array subset', the element you try to replace does not exist, that means the new element is not placed inside the array.
Use the following code construct instead:
Ton
My LabVIEW Ideas
(3,772 Views)
Hi Ton,
That works well. Thanks.
-Tim
(3,764 Views)
