multiple vi instances
I have the same VI being called a few times, which I have working. But each instance needs to have different parameters passed to it.
I have set it up along the lines of: http://digital.ni.com/public.nsf/allkb/9CE784F50F816EA18625751900775EBB
Is there a way to access the connectors of the sub VI?
Michael
Message 1 of 13
(5,386 Views)
Hi Michael,
If you connect a type specifier to "Open VI Reference" you can use the "Call by Reference" node to call the VI.
To create a type specifier, right-click the corresponding connector of open VI ref, create a constant and drag the VI you're going to call dynamically on the constant.
Hope this helps,
Daniel
Message 2 of 13
(5,372 Views)
Accepted by topic author lax815
You can't exactly access a clone's connector pane, but you can pass data to it. There is a VI method that you can access through an invoke node (called Ctrl Val.Set) that allows you to set the value of controls on the clone's front panel as long as you know the control's name. Call this method to set the inputs before you run the clone.
Mike...
PS: if you have a bunch of inputs, feel free to bundle them into a single cluster - just be sure to make the cluster a typedef!
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 13
(5,371 Views)
For what he's wanting to do a call by reference node won't work becuse it links the VI to the parent. He's wanting the called VI (actually multiple instances of the called VI) to be running independently.
Mike...
LabVIEW Champion
Message 4 of 13
(5,369 Views)
@Mike: are you sure about that? If you have multiple VI references obtained through the open VI ref by cloning the VI I thought you can have multiple independent instances of the VI. Whether you call the VI using the invoke node or call by reference node doesn't make a difference, you just need a strictly typed VI ref for call by ref.
I don't have LV here so I can't verify.
Message Edited by dan_u on 01-31-2009 09:43 AM
Message 5 of 13
(5,348 Views)
Just a thought...
If you need to pass different parameters, you just wire different parameters.
Normally one vi will wait for the other to finish before starting running itself.
If you need both to be running simultanusly you just have to make them reentrant.
It is much easyier, although i don't know if this is what you need.
Message 6 of 13
(5,338 Views)
@Mike: now I understand what you mean.
Of course you can't run the multiple instances in a for loop like the example does, because call by ref always waits for the SubVI to finish.
But you can still open multiple instances in parallel and call them simultaneously.
Daniel
Message 7 of 13
(5,335 Views)
Yes, that will work if:
  1. You know ahead of time how many instances you need.
  2. You don't have a problem with these parallel instances potentially blocking the execution of additional code until they finish.
Mike...
LabVIEW Champion
Message 8 of 13
(5,319 Views)
Thanks a lot for the responses - they sound like what I am looking for.
I can't find the Ctrl Val.... method in the list for the Invoke Node object. I am using LV 7.1.1.
The number of instances is fixed before run time, and the sub VI being called should run continuously once called.
Cheers,
Michael
Message 9 of 13
(5,263 Views)
The method is called Set Control Value or Set Control Value [Variant].
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 10 of 13
(5,249 Views)
