multiple subsequent loops
Hi all!
I'm building a VI which will run a number of subsequent tests. each test runs in turn inside a while loop until a certain condition is met, but I also want to be able to kill the operation with a single stop button at any time.
Currently I'm using a notifier and an additional loop for the stop button, but that method adds a lot of wiring to the VI, and makes it complicated to make separated subVI's from the tests.
Is there a cleaner way of doing what I'm trying to do?
a simplified version of the code is attached (instead of actually testing stuff I just made each loop count 10 iterations for the examples sake)
Thanks!
(3,931 Views)
Accepted by topic author shayelk
Hi shayelk,
Once you use NAMED notifiers you can easily create separate subVIs…
- Less wiring: use a global variable…
- Less wiring: use a FGV aka AE to hold your STOP condition…
(3,914 Views)
Thanks! I'll try it out...
One question though- what would be the best way to go about making the loops run one after the other? (as I know sequence structures are not recommended)
(3,858 Views)
You could create a data dependency by passing the error cluster along from one loop to the next.
(3,848 Views)
This is really the wrong architecture, overall highly flawed and overly complicated.
Just use a single loop and a state machine architecture and everything will fall in place.
Rethink the code from the ground up!
(3,822 Views)
Here's what I had in mind (LV8)
(3,811 Views)
