multiple scales on Y with the one time axis
Hi All,
I am trying to make a multiple scale in Y-axis with the single x-axis in XY graph or waveform graph. I am tring to do this programetically but I am getting the error message"LabVIEW:  Invalid property value." . I have attached the VI for your reference .
Please help me to plot multiple scale in Y-axis.
(5,005 Views)
Sorry, Forgot to attached the VI.
(4,990 Views)
Accepted by topic author SKant
Add the total Y  scales you need in XY graph.
Then you can hide or make it visible  using XY graph Y Scale  property node.
First you need to se the  'Active  Y Scale' property ,then  set any Scale property.
You cant programmatically add Y scales ,you need to  add Manually and programmatically you can do anything on Y scales with  above instructions
(4,956 Views)
Hi Dskp,
I am not able to find the Y scales setting in  XY graph properties. Could you please tell me how to add total Y scales in XY graph?
(4,929 Views)
You need right click on Y scale and select duplicate scale option to add new scale.
Attached a sample VI  having  XY graph with 3 Scales.
The  program will tell you ,the  Scale visible /Invisible function using Active Y scale Property.
(4,909 Views)
Thank you very much for support
(4,905 Views)
