multiple plots waveform chart
I'm having trouble displaying multiple plots on a waveform chart.  I used the help function, which said if you build the data into a 2-d array it will graph up to n-plots, but it's not working for some reason?  I'm sure there is an easy fix for this, I just don't see where I went wrong.
I'm using LabVIEW Version 8.2 (code attached)
(8,538 Views)
What you are doing does not make any sense to me. It looks like you want a separate plot for each mean. Even if your code was correct, you would not see anything because you have no point to display and you will obviously not have lines to display.
(8,525 Views)
Hey JJJOndae,
I m just showing two array plot on waveform chart in pic below.. i m not going inside ur mathematics calculation as ur logic in VI is difficult to understand.. so just showing multiple plots on waveform chart .. u can define ur logic as u per requirement..
Hope it helps
HS
(8,518 Views)
