multiple plots from a 1d array
I'm trying to take a 1D array of 6 elements andcreate a graph with multiple plots, one for each element.... and I'mstuck.  Does anyone know how I can do this?
Much Thanks!
(4,481 Views)
Hi Fibo,
do you need a graph or plot? You should use the proper LV names here...
See attachment, maybe it helps... Read the context help of graph/chart for examples of correct wiring!
Message Edited by GerdW on 12-17-2008 08:53 PM
(4,464 Views)
Accepted by topic author Fibo
Another option is "array to cluster". Don't forget to set the cluster size to 6 in your case.
Message Edited by altenbach on 12-17-2008 02:55 PM
(4,449 Views)
Thank you, that worked.... I was using merge signals, but the cluster solution seems a cleaner to me
(4,425 Views)
