multiple object tracking labview
I needed help in an emergency
I want to tracking multiple object (Detection and Recogition)
exemple :
(7,621 Views)
Hi Hamza.Chaouri,
What have you tried so far? Are you looking to use the LabVIEW Vision Development Module or OpenCV? What is your camera setup? There are a lot of factors that go into building a vision tracking system like this, so we need more details in order to be able to give any suggestions.
Also, there is a dedicated board for machine vision that might be a better place to post:
http://forums.ni.com/t5/Machine-Vision/bd-p/200
-Jordan
(7,559 Views)
I guess his dog ate his emergency.
Bill
CLD
(Mid-Level minion.)
(7,548 Views)
Thank you so much for your reply !
I tried with him a lot and took my time and did not Atousel the result.
I understand and work on it Vision Development Module but i have no information on OpenCV ,are there steps to follow to learn this property (OpenCV)?
What is important is the best way ?
Lifecam Cinema Camera
1313577f-2a54-4414-8bce-a2e8deb8ebc0.jpg_n=ic_lcc_2_otherviews01
(7,539 Views)
Hamza.Chaouri,
OpenCV is an open-source library of machine vision algorithms. This is what is being used in the first video you posted. There is a LabVIEW OpenCV library that can be installed through the VI Package Manager. If you're interested, more information can be found here:
Developing Vision Applications using OpenCV and NI Vision
However, the Vision Development Module already contains a built-in object tracking algorithm. Try taking a look at the Object Tracking shipping example. If you have the Vision Development Module installed, you can find it in the example finder or at C:\Program files (x86)\LabVIEW [version]\Tracking\Object Tracking.vi.
Also, did you try searching the forums before posting? There are a lot of threads about object tracking in LabVIEW with a lot of good suggestions and example programs:
How do you track a moving object using Labview and Vision Assistant
LabView object tracking (Vision Development Module 2013)
Object Tracking
Also, look on Youtube.
-Jordan
(7,517 Views)
