multiple line subdiagram label bug?
Subdiagram label doesn't shrink back when deleting a line. Am I doing it wrong or is this a bug?
I just updated to Labview 2013SP1
(3,112 Views)
Accepted by topic author AuZn
Yes, looks like a bug..... maybe.
Of Course you can simply grab the handle in the middle of the lower edge of the subdiagram label and resize it back to where you want it. 😄
(3,102 Views)
My sense is that this is probibly intended behavior since they just changed the "size to text" option in string constants to behave similarly: it will make the constant larger, but not make it smaller of you delete characters.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,100 Views)
I don't see that with string constants...
If it resizes if I add lines, it should also resize if I remove lines (Same as with free diagram comments and string constants).
As I said, you can always manually resize it back, so it is not a showstopper. 😉
(3,096 Views)
In terms of the sting constant thing, I forgot its string constants in an array that will size larger, but not smaller. Which if you think about it would be not unlike the situation of labels in a case structure.
If you grow larger, no harm done to the other cases,. But if it autoshrank, you could hide stuff...
Mike...
LabVIEW Champion
(3,088 Views)
Didn't saw that handle...
Then it is not a big problem.
(3,067 Views)
