multiple labview versions on single machine
Is it ok to istall multiple labview version (eg. 5.2 & 8.5) on single machine?
well I fee it very difficult to use... but sometime its required?
What NI recommends?
Message 1 of 14
(4,958 Views)
It is OK to use multiple versions.
No problems have been reported , as far as i know.
Message 2 of 14
(4,955 Views)
"Pnt" <x@no.email> wrote in message
news:1203421205962-656590@exchange.ni.com...
Should be fine. One thing to be aware of though is that (XP at least) will
load the last used version of labview if you open a vi via Explorer.
Something to bear in mind should you be using the 8.5 version, close it and
then open a 5.2 vi in explorer. 8.5 will open it no problem but do a save
without realising and you'll not be able to open it again in 5.2!
Richard
Message 3 of 14
(4,938 Views)
Hi Richard,
you can put the key "RegisterExtensions=False" in the LabView.ini to avoid this behaviour.
I run several versions of Labview (see signature) but only one version is allowed to register extensions (aka to run when opening a vi with explorer) - all other version get this key in the LabView.ini...Smiley Wink
Message 4 of 14
(4,932 Views)
What I have done is going into Windows Folder Options->File Types and setup additonal right-click menu items for each version of LabVIEW installed.  So I can right-click on a VI and choose which version of LabVIEW to launch.  I can also set the default option from Open to Open in LabVIEW 8.5, so if I double-click on it, then it always opens in the LabVIEW version I typically use.
Message 5 of 14
(4,927 Views)
Does anyone know if a VI file has a known set of bytes that can be read to know what version of LabVIEW wrote it?  If we knew that, we could make an utility that gets called when opening a VI from a folder.  That utility would then read the byte(s) and then pass the VI on to the appropriate version of LV.  If only a newer LV version is installed, it could optionally be set to warn you that the VI was written with an older version.  Is there a technical reason why this hasn't been done already?
- Brad
Message 6 of 14
(4,669 Views)
Hi Brad,
"Is there a technical reason why this hasn't been done already?"
Well, no! And it is done already - you just have to search the forum for this tool (I don't have the time to do so at the moment...).
Message 7 of 14
(4,648 Views)
It's called LabVIEW Version Chooser from DataAct.
Ton
EDIT: Hyperlink removed by moderator - DataAct website has been reported as an "attack site"
Message Edited by Support on 04-17-2009 08:34 AM
My LabVIEW Ideas
Message 8 of 14
(4,643 Views)
Firefox and Google Desktop do not like that site one bit.
Message 9 of 14
(4,628 Views)
we should remove this link, it contains spyware.
Mike
Message 10 of 14
(4,623 Views)
