multiple installation
Is that possible to install 2 different versions of labview on a same computer?
For example I've LabVIEW 7.1 installed and I would like to install a 5.1 version.
Has anybody try this?? Is there any trouble??
thanks
Message Edité par julesjay le 09-29-2005 05:02 AM
(4,277 Views)
it´s no problem to install different versions of LV on one PC. While my time by NI I had running up to 4 differnt versions. But there should run only one version at the same time.
Regards ThomasD
(4,262 Views)
You can also run multiple copies of labview (same version):smileywink:
see attached thread
http://forums.lavausergroup.org/index.php?showtopic=317
chow
xseadog
(4,250 Views)
You can have two different versions of labview runningat the same time.Smiley Happy
Not recommended in general setup- certain functionality is lost ( unable to find examples) .Smiley Mad
If you follow advice from previous thread then environments are stable.
xseadog
(4,238 Views)
And subsidiary question: I would like to install labview 5.1 on a  Windows XP computer.
it works or not?
(4,235 Views)
Check this links, http://digital.ni.com/public.nsf/allkb/A79C1377D512156C86256F320053186B
and http://digital.ni.com/public.nsf/websearch/E001E0210C5D259686256CE9005832D0
The problem will be, that LV 5.1 was offered, befor the OS Win XP was on the market. So there was no possibility to check LV 5.1 with Win XP.
Regards
ThomasD
Message Edited by ThomasD on 09-29-2005 08:08 AM
Message Edited by ThomasD on 09-29-2005 08:09 AM
(4,232 Views)
Hi julesjay,
Unfornutaley, we have made nothing for LabVIEW 5.1 and windows XP. You need test if during the installation do you have message with "Wrong OS", if do you haven't this message you can use it. But all computer with windows XP don't supported LabVIEW 5.1. See my link that we have customer they have try to install LabVIEW 5.1 under Windows XP.
http://forums.ni.com/ni/board/message?board.id=170&message.id=109246&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=140&message.id=6019&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=29473&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=61538&requireLogin=False
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(4,209 Views)
