multiple files version convert how?
Hi all, I have a folder with subfolders of labviews in LV 2009 version.  Is there a quick way to convert all of them to a older verson?  Or do I have to open and save as an older version one by one?  Thanks!
yik
(6,371 Views)
Create a new VI. Place all the VIs on the block diagram of this new VI. Then do a save for previous version on this "top-level" VI.
(6,354 Views)
Similar suggestion to smercurio's, except I add the folder to a new project and save that for the previous version.
Or, I sometimes use scripting.
(6,346 Views)
Sneaky...
I wish I'd thought of that when I need to back-rev reuse code......DUH! pretty obvious NOWSmiley Very Happy
"Should be" isn't "Is" -Jay
(6,341 Views)
I understand what you are suggestion, but I don't understand how this method will convert all the vis into an older version?  If I want to have both new and old version, do I have to make a copy of all vis before I use that method?
Yik
(6,317 Views)
Accepted by topic author jyang72211
Yik
NO ! what you will do is -
  • create a new project
  • add the existing folder to the project
  • save >for previous version
  • select a new folder when prompted
LabVIEW will "copy" the vi's in the folder to the new location and recompile all files in the folder for the previous LabVIEW version
(6,303 Views)
