multiple file path open
Wow. I'll have to study this a bit to see how it works. Right now it is asking me to open each file and then replace it, so my folder architecture may be different than what you had it set up for. I have one top level folder, inside of which is one sublevel with many folders such as I  included with the post, each with several files.
I'll post back. Some of this is rather elegant.
Tay
Message 11 of 13
(750 Views)
Actually, I just looked back over the code and noticed a couple logical errors. See the attached revision.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 13
(744 Views)
Ok, I looked into this file size issue. My code has no provision for dealing with text files that are blank, obviously. I'll figure out how to address that, since the machine that runs the test will generate blank files if the test fails.
This has been a great education!
Thanks Mike!
Tay
Message 13 of 13
(734 Views)
