multiple daq device
Im trying to run 9211 and 9229 to collect volatge and temperature at the same time, any hint how to ? PS..I am using NI DAQ 9172 module
(2,822 Views)
If you are using LabVIEW, then this may be a helpful article. Also take a look at this article, which describes how to create a task in MAX.  You will use one task including voltage and temperature measurements because they are sharing the sample clock on the cDAQ-9172 backplane.  Selecting the temperature task will automatically scale the data for you.
h_baker
(2,790 Views)
