multiple columns with uneven rows
Good Evening Everybody
Could somebody advise me on the best solution to do the following.
I have a csv file. The csv file is being read using "read from spreadsheet file" vi.
The file contains multiple columns. The columns all have a different last row address. By this I mean that...say...the last row of column 1 is 5. Column 2 last row is 23, Column 3 last row is 12. etc. The file might look like the following...note...this is an example of a file only, and any implications can't be construed.
            Column1    Column2    Column3    Column4     Column5
Row1        0               1                 2             3                 4
Row2       12             23              13            34                 0
Row3       11             44              23                               11
Row4       34             55
Row5       21
Lets assume that the value(s) of interest are contained in columns 2,4 and 5. Therefore the values I want to extract would be 55, 34 and 11
I can select the columns of interest fine, but am having difficulty working out how to find the last row for these columns
Caveats:
1. The number of columns changes
2. Position of column in file changes address...never found in same address
Does anybody know how I might be able to locate the last row in the column of my choosing.
Thanks for any assistance.
best regards
Ray
(2,533 Views)
Hi Ray,
load the csv as an array of strings. Empty cells will result in empty strings. So you can easily test each column for an empty item, which will mark the "End of Data"...
(2,525 Views)
Thanks GerdW
It was that simple
I'm constantly surprised at how seemingly difficult problems can be reduced down to some insignificant LV code.
I want to be a LV knight too, when I grow up.
kudo to you
Ray
(2,480 Views)
