multiple channels analog output
I am new to LabView 7...I have a PCI-6723 AO card & PCI-6034E AI card...I am attaching a vi which I built in 7 express to generate voltage outputs which need to be updated frequently for a 18 channel control. Could anyone please tell me if the code is correct? If it's right, then, I will have to start developing code for feedback.
Thank you in advance for your help.
(2,822 Views)
For some reason, the attachment did not go through. Here it is.
Thank you.
(2,820 Views)
Have you been able to run this code yourself to see if it works? What behavior do you see?
Also, you might want to check out the AO examples that ship with LabVIEW. LabVIEW >> Help >> Find Examples
Anuj D.
(2,789 Views)
