06-18-2008 12:41 PM
06-18-2008 12:44 PM
06-18-2008 02:26 PM
06-19-2008 04:57 PM
06-20-2008 01:14 AM
Hi Zappow,
please explain what you try to do. Your timer can´t do what you want, because you have an event structure in thie while loop. The loop executes only if you press a button. The same is with your stop button. If you press the stop buttons nothing happens til you press one of the voltage buttons. I recommed to use only one Event Structure per FP and you should create events for the stop buttons.
Mike
06-20-2008 02:29 AM
Zappow wrote:
However, with this setup, the time counter still doesn't work.
The event structure for all four buttons has a true boolean constant connected to my file-saving case structure. If I connect this to my elapsed time express VI reset button, the timer doesn't count.
06-20-2008 12:19 PM
