multicolumn listbox
I have a little problem. I would need to know if the user has selected some item of the multicolumn listbox, that is, If there is an item selected in the multicolumn listbox. I have use the value property but it doesn't work.
Some ideas?
ToNi.
(2,693 Views)
Hi, I do not understand why you had problems in getting the item selected in a multicolumn listbox.
Here is a little example on how it works. Your problem could be that if the lines do not exist you cannot select them...
Hope this helps !
Julien
(2,678 Views)
