multi string
Dears,
Actually am using a dll which will give a output string like this.
string1 followed by a null character
string2 followed by a null character
string4 followed by a double null character which indicates end of the string.
How can i extract it and display in a string indicator one by one?
Mathan
Message 1 of 9
(4,419 Views)
Hi mathan,
what do you mean with one by one? You can use the "Spreadsheet string to array" function and run through a loop to show every array entry in your indicator.
Mike
Message 2 of 9
(4,418 Views)
Dear mike,
Actually the dll returns 4 strings. (string1 with null character in the end, string2 with null character in the end.... string 4 with a double null character in the end.)
I need to show all the 4 values in a string indicator.
Hope i was clear this time?
Mathan
Message 3 of 9
(4,416 Views)
Hi mathan,
like this? If not can you please upload an example with example strings you get and the expected result?
Mike
Message Edited by MikeS81 on 06-20-2008 09:20 AM
Message 4 of 9
(4,411 Views)
Dear mike,
Actually the multistring output from the dll will be like this format (assume)
mathan\0mike\0partha\0JLV\0dennis\0ben\0altenbach\0rolfk\0tst\0ni\0\0
Then i need the output like this.
mathan
mike
ni
all values stored in a string array.
Hope i was clear.
Mathan
Message 5 of 9
(4,389 Views)
Hi mathan,
use the "spreadsheet string to array" function and delete the last two elements. Smiley Happy
Mike
Message Edited by MikeS81 on 06-20-2008 12:01 PM
Message 6 of 9
(4,386 Views)
Dear mike,
actually every name is terminated by a \0 (single 0) and finally the whole multistring was terminated by a \0\0 (double \0).
Mathan
Message 7 of 9
(4,382 Views)
Hi mathan,
i switched to "code display", that´s the reason for the "\00". You can use every other delimiter.
Mike
Message 8 of 9
(4,377 Views)
yes mike,
its working. thanks a lot.
Mathan
Message 9 of 9
(4,371 Views)
