09-10-2008 07:15 AM
I'm wondering how I can write a string array with more than two dimensions to a table. Specifically what I want to do is this:
I am currently writing a 2d array to the table. Column 1 consists of the channel names from my DAQmx task and Column two is the current data for those channels. What I am trying to do is to split that up into a '2 column view' so that:
Column 1: 1st half of the channel names
Column 2: 1st half of the data
Column 3: 2nd half of the channel names
Column 4: 2nd half of the data
Here are the steps that I've done to try and make this work:
I've split the original 2d array in half by using the 'delete from array' vi which outputs both parts that I need then putting that through the build array vi. When I do this, the data wire out of the build array vi is of type '3d array' I'm thinking it should be a 4d array and I'm not sure why it isn't. When I try and wire the table to this it will not allow it because the sink type is for 2d arrays.
Any advice or suggestions?
09-10-2008 07:26 AM
Hi scrook,
that you get a 3D array is absolut correct.
If you have two 2D array, then the next dimension is 3D. Draw a 2D array on one paper (your first part) and a 2D array on another paper (your second part). If you combine them, put one on the other you get a 3D array. ![]()
But you need a 2D array.
See the attached example, pelase.
Hope it helps.
Mike
09-10-2008 08:20 AM
Mike,
I see what you mean. Thanks for giving an example of how to do it correctly.
