ms2036a loading a calibration file
Could I have some assistance as to if there is a way to upload just a calibration file instead of invoking or calling the whole equipment set up (stp file extension), as it is done on Anritsu model 37369A.
Loading a calibration file on the Anritsu model 37369 is very quickly but on the ms2026a it takes over 20 seconds to upload a calibration file, because the whole equipment set-up needs to be called ("xxxx.stp").  Is this assumption correct?  Thanks,
Frank
(2,612 Views)
Hi Frank,
I could not find the Instrument Driver for the Anritsu model 37369A, so I dont know exactly how it is uploading the file to the instrument.  What I would recommend to do is look at the block diagram of the VI that allows you to upload that file to the 37369A, and see if you can alter it to work with the MS2026a.  It might not work because it might be a limitation of the hardware, but that would be a good place to start.  Have a great day!
Michael
Applications Engineering
(2,595 Views)
Thanks Michael!  I would look into this. . . Frank.
(2,582 Views)
