ms graph, setting tickmark spacing
I am trying to progamatically set the x axis tick mark spacing when using report generation toolkit to insert an ms graph into word.
I have tried expanding out the "major tickmark" element in the  property node of word set scale.vi ( see attached). But, I get an undefined error when wiring a numerical input to it.
Does anyone know a way to set the tickmark spacing?
Jim
(2,593 Views)
Jim,
You might want to consider the property TickMarkSpacing instead. Microsoft actually does a really good job of documenting their ActiveX methods/properties and I have linked a page outlining all of the properties for the Axis class. There is a brief and more detailed description on each property and you will need to do some deeper digging for what constitutes a valid input value for a property.
Kind Regards,
E. Sulzer
(2,572 Views)
