moving elements from array to array
I am on the west coast just having my coffee ☕. I'll have a look once I am near a computer 💻.
Have you looked at the debugging tools yet? (Execution highlighting, probes, etc?) It's like open brain surgery!
Message 31 of 84
(2,774 Views)
I tried Highlight execution, and the data seems to flow through the false case of the 5th queue, but I still don't know why.
Message 32 of 84
(2,767 Views)
Probably because you did not invert the lower input to the compound AND (notice the little circle?).
Message 33 of 84
(2,759 Views)
Thank you that fixed it and I was able to code the rest of my queues,
Now I just want to ask if I can also add a function that counts the time an element takes to get from queue 1 to queue 7.
Message 34 of 84
(2,753 Views)
I tried adding to the clusters a "time" section along with category and life expectancy, but then I didn't know how to make it start counting time.
Message 35 of 84
(2,750 Views)
Very similar to what we use to see if entries expire.
Message 36 of 84
(2,745 Views)
But then how can I isolate it for the individual elements.
Message 37 of 84
(2,741 Views)
Currently, you write two items to the cluster. Once you have also a time element, write that too.
Message 38 of 84
(2,727 Views)
Can I just ask what does this circled area do, because I tried adding a third control into the cluster and  I expanded the index array function but then I got those wiring errors, also I tried expanding the bundle by name function, but then I didn't get the third element that I added into the cluster.
So what did I do wring.
Message 39 of 84
(2,676 Views)
Can you please tell me what does this circled area do, because I tried adding a control to the cluster in the front panel and I expanded the index array function but I got those wiring errors. Also I tried expanding the bundle by name function but I didn't get the third element that I added to the cluster.
So what did I do wrong
Message 40 of 84
(2,703 Views)
