move the curve on a graph
HI!
With my program in the attachement i can compare several curves on the graph. On the next step i want to move the curves on the graph, without the first curve, because this curve should be date reference-curve. I want to compare the other curves with the first curve!
To move the curves on the graph i placed four buttons to move the curve left, right, up and down.
I tried several solutions but when i tried to move the curve on the graph, no gurve was shown on the graph or nothing happened.
I hope somebody could help me, please???
PETER
Labview 7.1 on Windows 2000
(3,205 Views)
Sorry i have forgotten a SUBVI!
PETER
(3,195 Views)
Hi Peter,
I look to your code. But I don't found any code for 'ARROW' buttons.
That will be your problem 🙂
Best regard
 JCC (SK)
(3,186 Views)
HI!
Sorry, it was the wrong version.
I have solved the problem!
In the attachement the program!
Peter Fischbacher
(3,184 Views)
now is it ok.
If I can recommend to you .... run your code and chack how too much CPU time need you application. There is not good for other applications in your 'OS'.
Solution: Always (coon always) inser to 'While Loop' small delay - 'Wait' vi. In this case are 50 ms be enough.
Have a nice day.
 JCC(SK)
(3,176 Views)
