mouse wheel problem with scroll bar and value change event
I have an event that triggers when the value of a scroll bar changes. This works fine with everything but with the mouse wheel. At first, the mouse wheel will change the value of the scrollbar, but this won't trigger the event. If I then trigger the event with a mouse click, the mouse wheel will then start to trigger events as well. Then switching to another object makes it revert to not recognizing mouse wheel value changes.
Is there a way to make it recognize the mouse wheel without having to change the value of the scroll bar with a click first? I've attached a sample vi.
Message 1 of 21
(5,793 Views)
Hi hbcnb
For me your example works as long as the mousepointer is over the scrollbar. Please have a look at this thread (post 12) for an example on how to use the mouse wheel as an event trigger instead.
Best Regards
David
NISW
Message 2 of 21
(5,759 Views)
I sort of saw the behavior you are talking about.  When I first open it, the event values didn't change when I scrolled the wheel while it hovered over the scroll bar.  When I clicked on it, then it would fire events after that.  Even when I stopped and restarted the VI, it would continue to work.  Clicking elsewhere, the scrolling still worked.  (This is a bit different than what you described where you said clicking elsewhere caused the scroll events to stop working.)
Part of me says there is somehow a focus action going on that is allowing or not allowing the value change event to fire.
If you duplicate your code and do two scroll bars, and two event cases, and another polling loop, how does it behave.  I tried that, and the scrolling behavior fell apart.  I just tried again and LV2009 crashed on me.  It disappeared with no message.  I was able to recover the VI, but there was no message about error logs.
I'm going to attach that VI for others to play with.  WARNING:  Make sure you have all of your other LV VI's saved so that it doesn't close them out as well if it crashes.
David, that link you posted is a dead end.  Reply 12 just points to a LAVA link that is no longer present on the LAVA servers.
Message Edited by Ravens Fan on 12-01-2009 10:16 AM
Message 3 of 21
(5,750 Views)
darn, I used that just a while ago but I don't think I have it saved anywhere (new computer)....sorry.
I'll try your VI right after finishing some other things
Best Regards
David
Message 4 of 21
(5,746 Views)
Ravens Fan:
You're right, you have to do more than just click off the scroll bar control to make it stop triggering value change events with the mouse scroll. It looks like you have to make a value change in another control to do this.Just clicking on another control will not do it. Also, just clicking on the scroll bar does not cause the mouse wheel to start triggering value change events. You have to actually make the value change. At least that's what I'm finding
Message 5 of 21
(5,736 Views)
I've found much the same thing. If you open the VI and run it the event won't fire until you change the value of the scrollbar with the mouse, simply clicking on it won't help. I haven't been able to reproduce the crashes with two scrollbars, I get the same behavior as with one. Have you been able to get it to crash again Ravens Fan?
Best Regards
David
Message 6 of 21
(5,706 Views)
Best Regards
David
I was able to reproduce it.
Please watch the attached swf file.
I just open the VI
Run the VI
Without clicking on anything else hover over the first scroll bar
Then I did (scroll, scroll, scroll) three scrolls of appx equal durations and with appx equal gaps in between.
The duration I used was small.
Message 7 of 21
(5,701 Views)
Tried it, but mine doesn't crash. Which version of LV are you on? If it's 2009 do you have f2?
Best Regards
David
Message 8 of 21
(5,696 Views)
I tried it on LV 2009 and LV 8.6. I don't remember installing f2 patch :). I'll install the f2 patch and get back to you. In the mean time, I have filed CAR# 198046 for this crash. I will post updates if any more info is required.
Davidek, try scrolling furiously and check if it is crashing for you.
Message 9 of 21
(5,694 Views)
Tried that too, stil no crash
/David
Message 10 of 21
(5,692 Views)
