mouse cursor position on image with subpixel precision
Does anyone know how to retrieve the current mouse cursor position on an image displayed in an image control with subpixel resolution?
I know you can retrieve the current cursor position with the "Last mouse position" property. However, this only gives you pixel accuracy. Is there a way to obtain this location more precisely?
Greetings, Manfred
(3,705 Views)
I don't know if that's possible.  Out of curiousity, may I enquire as to why you need this information?  Maybe you can get it in an indirect fashion by seeing how they do ClearType?
Bill
CLD
(Mid-Level minion.)
(3,696 Views)
I'm writting an application that displays a crosshair at the current position of the mouse cursor. If the user zooms in quite a bit (for editing the edges of a graphical object) the displayed crosshair is not matching the cursor position which looks odd.
(3,692 Views)
Is it possible to work around this issue by only letting the user zoom in factors that will result in integer values for x and y?
Bill
CLD
(Mid-Level minion.)
(3,684 Views)
This will not solve the issue. The mouse cursor moves in screen pixels. Once the pixels of the image become larger than one screen pixel the coordinates (and hence my cross hair) will be off from the actual position of the mouse cursor.
(3,679 Views)
Accepted by topic author mprantl
The way I see this solved in other applications that zoom like this is to have the cross-hair "follow" the cursor - that is, you'll have to calculate the "sub-pixel" size in real pixels, then have the cross-hair "snap" to that location.  Every time the cursor crosses a "sub-pixel" boundary, it "snaps" to the new location.
Bill
CLD
(Mid-Level minion.)
(3,647 Views)
If I understand you correctly then this is precisely what "Last Mouse Position" is doing.
Probably, there is no other solution so I will go with this. Thank you for your answers.
(3,642 Views)
