monitoring the error
Hello everybody
I have one error dialog which shows the error during run of vi. I
would like invoke it couple of times while vi is runing. The
dialog is also connected with the bollean indicator. Sometimes is
on and off.
How shell I invoke this dialog and bollean every time when I need
it?
I do not know if I explained what I whant, so in another words I
would like to have the monitoring tool to check out values in
different point of vi, while it is running?
Many thanks in advance
Best regards
PP
(2,769 Views)
OK, I found it, solution: "Change to write" 🙂
Best regards
PP
(2,769 Views)
Hello
It is not OK, I found it but within the same vi, how to do
connect the property node in child vi's.
PP
(2,769 Views)
