monitoring labview crashes
I have a LabVIEW vi that automatically opens when the user starts their computer. I want the program to be transparent to the user, therfore, I was wondering if there is a way to monitor the vi to ensure that if LabVIEW crashes it will ideally be restarted or the user will be alerted to restart it.
Thanks!
(3,471 Views)
You probably want to run this in the runtime engine if you are concerned about the development engine crashing. This would be the only way to accomplish what you are trying to do anyway. There is no way to have LabVIEW start a VI automatically.
I don't know how to get an executable to start over if the runtime engine crashes however.
(3,471 Views)
Thank you for your suggestions.
I appreciate your help.
(3,471 Views)
You might look into some third party application monitoring software. I think there is some software out there that can monitor crashes and potentially restart things after a crash. Here is a link to a product that looked promising:
http://www.sophisticated.com/products/kick-off/kick-off_win.html
(3,471 Views)
One possible way is to write program what monitoring is LabVIEW open or not,
if not RUN IT.
I use VC++ and these functions.
FindWindow(NULL, "LabVIEW: labview.exe - Application Error"); (if LV is
crached, i receive this window,
also you can monitor window with any name)
PostMessage(hdlMsWheel, WM_QUIT, NULL, NULL); // Close Crach error window
automaticly
CreateProcess() // Run LabVIEW.
I hope, it help you.
Deniss Karai
"ergolab" wrote in message
news:506500000008000000525A0000-1027480788000@exchange.ni.com...
> Hello,
> ensure that if LabV
> Thanks!
(3,471 Views)
We have solved this problem by having another executable running (restart.exe) that monitors the main.exe. If the exe is no longer running then the restart.exe program will restart the main.exe.
It works well!
(3,471 Views)
