modularity index computation
The company I work for is now getting into the VI metrics analysis of our programs and I am struggling with the Modularity Index. According to the Style book, the value is computed by
# of VIs / total node count * 100.
In the image, I get a value with the calculator that varies from what the Analyzer reports. Can someone tell me how the Analyzer computes that value?
Tay
(3,380 Views)
Hi Tay,
You are correct with the equation for the modularity index. I don't know why you are getting a modularity index of 0 for that vi. Could you post the vi for me to take a closer look?
Thanks!
Joe Daily
may the G be with you ....
(3,344 Views)
Here you go...
By the way, LabVIEW 2009 Service Pack 1
Message Edited by slipstick on 06-08-2010 08:00 AM
(3,311 Views)
Hi Tay,
I looked at your code and was unable to reproduce anything. Would you mind posting the code again with the project and with the vi analyzer task.
Thanks!
Joe Daily
(3,290 Views)
Here it is...
The VI Analyzer Results folder contains the config file and not results. Not my call on the name...
Message Edited by slipstick on 06-08-2010 09:14 AM
(3,287 Views)
So I look at much more in depth and the problem is actually expected as the modularity index is subvi's/nodes and if there is no subvi's it is 0/X = 0.
Hope this helps.
Joe Daily
(3,260 Views)
