modify waveform graph
Is there some way to remove the 'cursor buttons' from the waveform graph?
There is a cosmetic issue when I resize the front panel of a data analysis tool... If I 'shrink the window, the cursor buttons are displaced to odd locations (such as on top of the cursor legend). Then when the window is 'grown' to a larger size, the buttons stay on top of the cursor legend.
Any ideas?
(2,607 Views)
You can use the colour tool to paint it transparent. I know that's an ugly work-around.
Usually what I do (aother work-around) is to place it below the graph, you can move it independently from the cursor legend and set it at the back (hit Ctrl+Shift+J when it's selected to move is to the back).
I don't think it's possible to make it invisible when the cursor legend is visible.
Epictetus
Antoine Chalons
(2,605 Views)
