modified a table
anyone can help me modified this vi so that i can assign title for each column?
i want to make the 1st column to 'number1' and 2nd column 'number2' .....
Message 1 of 23
(5,813 Views)
use the property note "column header strings[]" for the same.
Regards
Guru (CLA)
Message 2 of 23
(5,810 Views)
can u send me the vi please
Message 3 of 23
(5,795 Views)
You have to use table so as to use property node mentioned in previous post.
Have a look.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 4 of 23
(5,790 Views)
thanks for that..but how to make it also visible when i save it to file?
Message 5 of 23
(5,783 Views)
here you go.
Gaurav k
CLD Certified !!!!!
Message 6 of 23
(5,777 Views)
sorry..i try it and my input number dont save at all
Message 7 of 23
(5,769 Views)
I forgot one thing.
Create local variable of the "Table" and connect it to tunnel in "Stop" event case.
As shown in the image.
Gaurav k
CLD Certified !!!!!
Message 8 of 23
(5,766 Views)
it wont connected..i dont know why
Message 9 of 23
(5,753 Views)
my input number also cant be saved in file when the shift register wire disconnected from write to spreadsheet function
Message 10 of 23
(5,749 Views)
