modification of frequency sweep.vi
Hello.
I am trying to measure frequency sweep data using function generator(agilent 33250A) and oscilloscope(DSO-X-4024A).
But I have some difficulties making frequency sweep when I use "configure frequency sweep.vi".
The difficulty is that frequency sweep is repeated automatically until I will stop the program.
Before describing my problem, Let me explain "configure frequency sweep.vi".
I should give some data to "configure frequency sweep.vi", 'start frequency', 'stop frequency', 'sweep time', to use this vi.
For example, If I start the "configure frequency sweep.vi" with 3700Hz(start frequency), 3800Hz(stop frequency), 100s(sweep time), the program will be repeated automatically after the frequency reach the stop frequency.
Let me describing my problem.
I want to make the frequency signal will be held when the frequency sweep reach a stop frequency that I set.
For example, If the frequency reaches the stop frequency(3800Hz), the function generator will emit the signals(3800Hz) until I stop.
I want to discuss this problem with you.
I attach a block diagram of "configure frequency sweep.vi".
(5,196 Views)
This is from the manual. It looks like you need an external trigger to do what you want.
(5,185 Views)
Thanks for your replying.
I knew the fact.
but the external trigger provides only 1 time frequency sweep and output will be not held after 1 time frequency sweep.
(5,174 Views)
I don't have an Agilent 33250A. Quickly looking at the manual, I think you have a hardware limitation with that SigGen model.
I do have a slightly newer model (Agilent 33521A) and it has two additional sweep parameters: "hold time" and "return time". I was able to easily create your waveform. Probably time to either redefine your test waveform, or find other hardware that meets your needs.
(5,158 Views)
I was thinking that you may have another option:
It looks like you want to scan from 3700Hz to 3800Hz over a 100 sec sweep time. That's a 100 Hz delta over 100 seconds, or a sweep rate of 1 Hz/sec
You could programmatically create a loop to update the frequency by 1 Hz every 1 sec. That is if you can live with the discontinuities of a stepped sine wave. Also, the hardware will not switch frequencies at exactly 1 sec intervals. It take a finite amount of time to send the command, process the command, and for the waveform to settle. However, the advantage of doing it this way is that you could synchronize/trigger the o'scope to capture a CW waveform during that 1 second interval.
(5,150 Views)
After reading your replying, I check the manual of Agilent 33250A.
Unfortunately, this model doesn't have the function("hold time" and return time".)
(5,140 Views)
Actually, I made the program as you said above(prgrammatically repeat a loop to update the frequency by 1 Hz every 1 sec.
But, I want to make the frequency increase with continuously data.
I mean that there will be so many data between 3700Hz and 3701Hz.
(3700Hz, 3700.0001Hz....3700.9999Hz)
But the program that create a loop to update the frequency creates only point of signal.
(3700Hz, 3701Hz)
So I am trying to make a program using "configure frequency sweep.vi".
(5,139 Views)
