modem to modem
I need to run a data acquistion application on one computer
and control it using vi-server vi's from another computer.
This is fine for typical ethernet connections to the internet,
but my problem is that the computers will be connected
directly to each other via modems.
Is it possible to do such a thing? Where do I start to learn
how to do this? The machines are NT workstations.
thanks,
-H.
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,251 Views)
One option is to use Win32 API ( RAS, etc ).
You may need support from someone familiar with the Win32 API calls, also
some C code "wrappers" may be necessary, in order to allow access from
LabVIEW.
The part that I like, is that you can dial-up, hang-up, etc., without any
concern for modem control strings and other modem setings.
Let me know how this works for you.
Cheers, Dan
(3,251 Views)
In article <956878486.400199@neptune.uniserve.ca>,
> calls, also some C code "wrappers" may be necessary, in order
> to allow access from LabVIEW.
> without any concern for modem control strings and other modem
> setings.
> Cheers, Dan
Thanks Dan,
Actually, I was hoping to pull this off using RAS dial-up
networking in NT. Isn't that possible? It would sure make
things complex if win-api calls had to be done.
Has anyone been able to do modem to modem networking for
the purpose of doing
vi-server stuff?
-H.
Before you buy.
(3,251 Views)
To use the VI Server between two computer you need them to be networked
via TCP/IP.
A workaround is to reroute data to/from a TCP/IP port from the client
computer to the VI Server port of the server computer thru modem (or any
other data link). It is not necessarly less complex than win-api calls.
Jean-Pierre Drolet
Scientech R&D inc
Trois-Rivieres-Ouest (Quebec)
CANADA G8Z 4H1
a écrit dans le message :
8ebs92$h9d$1@nnrp1.deja.com...
> the purpose of doing vi-server stuff?
> Regards,
-H.
> Before you buy.
(3,251 Views)
