mode function in statistics
I have an array of intergers and I want to find the most commonly occurring element in the array. I thought this was the definition of Mode in statistics. however, the mode funciton returns a floating point value. If I have an array with 19 elements, 17 are 50 and two are 150, the mode funciton gives me 50.25 as the result. I would have expected the result to be 50. I don't mind writing my own funciton, but what is the native statistics function doing here?
_____________
Creator of the BundleMagic plugin for LabVIEW!
(5,505 Views)
Hi sphaeroid,
usually you use a histogram function to detect (ranges of) the most common value(s) in your data…
Mind to attach a VI with default data (and expected result)?
(5,499 Views)
Hi Gerd:
I gave my example already, didn't I. I'm asking about what mode means. I was taught it means most commonly occurring value value. It's a counting function. I see that it is not implemented this way in LabVIEW, but then I'm not clear on what LabVIEW's mode function is.
_____________
(5,485 Views)
Hi sphaeroid,
there is no example VI in your first post, just some words…
Did you read the help for the Mode function? It explains the behaviour in the "details" section!
(5,478 Views)
littlesphaeroid,
The Mode VI has an input called Intervals, which specifies the number of histograms it uses in the algorithm and then returns an estimated mode. If you want this function to return the exact mode, then set Intervals to 0. You should then see a result of 50 instead of 50.25 for example.
(5,450 Views)
Others have said it already, but here is the linked help on that function.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/baseanly-llb/mode-vi.html
This help is instealled with LabVIEW.  Open the Context Help (CTRL+H) in LabVIEW and hover over this function.  In the help window there is a button for detailed help that has this same information.
(5,443 Views)
Thank you elcalverado! This makes sense and now I understand. I was not aware that mode could mean anything else! Your response was helpful.
_____________
(5,414 Views)
