modbus help
Hello Everybody,
I am a last year student at University College Oslo, Norway.
I am having my project where i have to establish ModBus communication between two simulators made in Labview and a PLC (315 2PN/DP). I bought modbus library from it4business, I did everything i could according to manual followed by Modbus Library. I think i have little bit problem in parameterisation of the DBs because i got sucsessfull in establishing connection between PLC and the PC with Labview simulator but problem is that i cannot receive data from simulator.I am using modbus tcp and I have used the modbus example and modified it in labVIEW. Can anybody help me plz having any example of such a program send me at kristinep80@gmail.com ,example followed by Modbus library didnt worked for me, or can anybody help me if i send my copy of program just email me.its urgent
Thanks and Regards
Kristine Pettersen
(3,010 Views)
HI
If you have establish communication with PLC, then check if you are missing following things.
1. Go to Tools> Options > and select VI server : Configuration
2. Change TCP/IP port to 502
3. Go to VI Server : Machine Access and IP address of another TCP/IP device
Hope this helps
(2,988 Views)
