modbus - example error
i downloaded NI Modbus library and started MB Ethernet Example Slave and MB Ethernet Example Master. But when i start Master im getting error:
Error 56 occurred at TCP Read in MB Ethernet Receive.vi
LabVIEW:  The network operation exceeded the user-specified or system time limit.
Open TCP connection is ok, but when it goes to MB Ethernet Master Query Read Discrete Inputs im getting error.
I work with other PLC and i need to connect via Modbus - but i really have no idea how to test Modbus when even example didn't work.
I appreciate if someone can tell me how to test Modbus properl.
(2,954 Views)
Seems you have recieved a timeout error, because of the connection.
I would recommend you tested it like that:
1.Open both Master and Slave in LV.
2.In master set the remote ip address: localhost
3.Execute slave, execute master
Perform changes on the master, and see the functionality on the slave, and vice-versa.
Good luck,
Mircea
(2,939 Views)
