modbus RTU protocol datatypes
hello Raghunathan,
                              find attached Vi..same Vi m used in my project and it works. it  built in LV8.5
Message 51 of 58
(2,378 Views)
Hello Shublaxmi,
I tired my level best - but the VI continuously returns "Modbus Exception code 6002". Running with the trace ON, I noticed that there is a problem in the String+CRC that is being generated. Uptil then  there is no Error in VISA, MBSerial Init etc
Since I do not have LV8.5,  I ran the code in LV2009. Not sure if that is a problem. ( I already have a identified bug with charts in LV2009 but thats a different issue )
Not sure what could be wrong ....? And I am using a direct COM port without a 232 to USB covertor.
Raghu
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
Message 52 of 58
(2,362 Views)
 Hello Raghu
                   u told u have LV8.6 so run my code in there...i have also used direct com connection without convertor....same thing i did as u are doing now....use Visa Serial instead of Mb serial init...some times it gives error....try it
Message 53 of 58
(2,354 Views)
I am new to this forum. I am trying to communicate with the conzerv energy meter via modbus. I program in c language. I am not able to access any of the files
since they are *.vi could you please send me a sample code in doc format.
Message 54 of 58
(1,671 Views)
since they are *.vi.
You are asking for help at he wrong place.
This is LabVIEW forum, not C/C++ forum. Maybe, you need to look in LabWindows/CVI forum instead.
.vi means a Virtual Instrument, it is a native LabVIEW program file. It wont open in any graphical editor unlike C/C++, as LabVIEW is a Graphical System Design Platform or, to put it simply, a Graphical Programming Language.
- Partha ( CLD until Oct 2027 🙂 )
Message 55 of 58
(1,668 Views)
Hmm.. the wrong question at the wrong forum !! Anyway Deeky, forget the *.vi files as  they are of no use in your C environment. But of course getting the Conzerv unit to talk to your C code in MODBUS is no big deal and possibly i can help you on the concept if you can mail me at ragunath73@hotmail.com
Raghunathan
Message 56 of 58
(1,661 Views)
Could you please give me your current email id? It would be of great help if you could clarify few technical issues with conzerv energy meters.
Message 57 of 58
(1,656 Views)
I have sent you a mail with the details.
Message 58 of 58
(1,653 Views)
