modbus DSC
Good morning,
I want to make a NI cRIO9073 speak with a Maple HMI (Touch Screen) using an RS232 connection. Unfortunately, I have no previous experience, thus I have to confront lots of difficulties. In order to obtain this communication up to now I made some efforts which include: create a project, adding the cRIO ,then create an I/O modbus slave server and finally a shared variable. I have doubts about the properties setting of shared variable. What kind of variable type do I need, enable aliasing? What I was trying to do was writing to a DO channel of cRIO as a first test. I am attaching a screenshot of the project I made. Up to now I tried to apply instructions I found in the link: how to turn an RT target into a Modbus slave using I/O servers, however for serial (RS232) connection, but my HMI displays a message that can’t find the PLC. I checked settings like baud rate etc and everything seems ok.
Any possible help or instruction will be appreciated
Thank you in advance
(3,367 Views)
Hi thorfano,
Can you read the variables on the cRIO?
Flash
(3,344 Views)
Hello A_Patel,
Could you please be more specific? I have no interface to read or write since HMI displays a message that can not find the PLC. Of course I can read and write if I use as interface my PC (by creating the proper vis of course).
Best Regards
(3,315 Views)
Hi thorfano,
I take it you do not have LabVIEW DSC. Is this correct?
In that case you will need to use the Modbus library. Found here:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
Flash
(3,295 Views)
Hello A_Patel,
I have downloaded the DSC module in a trial version. My intention was to check that my work can be done this way and then buy DSC. I am afraid I am too unexperienced to use the other way you propose (using the Modbus Library).
Best Regards
(3,281 Views)
Hi thorfano,
Did you follow the instructions on the following to set up the variable:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YFeECAW&l=en-US
Also, have you been able to communicate with the PLC with anyother software?
Flash
(3,261 Views)
Good Morning A_Patel,
Yes, I have already used the link proposed and already checked that the server works by using my PC as interface. In addition, I have already tested the functionality of cRIO (I have written and read to and from the same DO channel that I am trying to use in the touch panel application). I am afraid that it is difficult to solve the problem (if it is a problem and not luck of communication between the two devices, Touch panel and cRIO, due to software issues). Anyway, thank you for your consideration.
Best Regards
(3,251 Views)
