mixing fonts
How would I make a label - ROTATE A CCW - where the A is the Greek alpha?
(3,617 Views)
You can get the alpha character by typing Alt+97 with the keyboard, and then changing the font to Symbol.
I would recommend to use the caption instead of the label.
Message Edité par JB le 02-29-2008 03:57 PM
(3,612 Views)
I'm on a MAC so it's apple 0 and I'm not sure about the alt+97 but I got to work.
(3,603 Views)
Nope. I was able to open a text window and do get what I wanted but when I tried to apply that to the label is on a button, it wouldn't work changing the font of the whole text.
(3,597 Views)
You should be able to selectively change a single character's font by simply highlighting it and then selecting the font you want. You will need to select a font that has the symbol you want, and type the character that corresponds to that symbol. This is how I created the Greek delta symbol on a control's caption not too long ago. And I agree with the comment that you should do this on the caption, and not the label.
(3,592 Views)
