mixed string
Is it possible to concatenate a string with numbers and characters? Thank-you, Ivanka
(3,219 Views)
Concatenate strings will only concantanate strings - hence the name. If you want to use this function, you will have to convert your numbers to strings first. A better solution would be to use Format Into String. You can mix strings and numbers just by specifying the correct format string. For example, %s %s %f will create a string from 2 string inputs and a number.
(3,219 Views)
Ivanka;
Yes, it is possible. All the functions are in the String menu on the function palette. Check the VI Format into String, and the VIs under the String/Number Convertion menu.
Regards;
Enrique
www.visecurity.com
www.vartortech.com
(3,219 Views)
Thank-you!
(3,219 Views)
Thank-you!
(3,219 Views)
