missing file compute waveform.vi
i wrote a program a while ago in labview 8.5.1.I have installed 8.6 since. Now when i try and run this same labview program, there is a block "compute waveform.vi" missing in my program.(it has a questioni mark where this block should be). I cannot find how to insert this missing block and  now i cant run this program. any help?
(2,850 Views)
Hi Gillyme,
I believe that compute waveform.vi is a Traditional DAQ VI.  If you wish to continue using it you will need to reinstall the Traditional DAQ driver, the latest version of which can be found online here.
Alternatively, if your device is supported by DAQmx, then this article may help you convert your code to the newer driver (which can be found here)
I hope this helps.
Sheela Sujeeun
National Instruments UK
(2,836 Views)
Hi gillyme,
I hope the info I posted was useful to you and solved the case of the missing file.  If you are still having problems tho please do post back.
Sheela Sujeeun
(2,808 Views)
