messageboxtimeouta
I want to invoke the MessageBoxTimeoutA function from the user32.dll. With the attached code the popup window appears, and 2 seconds later the complete LabView will be down. What is the problem, the parameters?
MB
(3,176 Views)
Accepted by topic author mitulatbati
Strange, it works for me without any troubles (LabVIEW 2011/Windows 7).
Otherwise, its not good idea to use undocumented WinAPI function - MessageBoxTimeoutA officially not supported by Microsoft as far as I know.
Also check calling conventions - may be you have C. Shouls be stdcall (WinAPI). And show you code finally instead if gif screenshot.
Andrey.
(3,169 Views)
It was the problem of the calling convention. I have to use standard (WINAPI), instead of C.
(3,161 Views)
