mess
hello all
we have several vi that are in several directories , this vis use configuration files (txt , xml) that in other directories.
more : the main vi uses dll's of c++ that in another directory , more : the dll's uses configuration files that in another direcrtory
more : we build application inanother directory , more : we have several versions of the main vi for difrent products , we change somtimes the subvi's. the main problem when we make new version and copy all main directory with subdirectories the main vi goes to the older directory !!!.
so i hope i explained the big mess here we lost our legs and hands how we can make some order around here please help quickly
(2,668 Views)
Well keeping track of multiple sub Vi's and its dlls is indeed a messy job if right care is not taken.
we have had our share of misery in similiar situations before getting things right  😉
try following to make things easier.
  • try to save your Main VI and its sub VI's a development distribution (*.lib) from 'save with options' in file menu.(also check selected options column while doing this)
  • as much as possible keep renaming any changed sub VI's so that they do not clash with unchange ones if they are used by other VI's
  • Delete any obsolete or unused Sub VI.
  • always avoid opening two main Vi's that use sub Vi's with same name(unless they are sharing  the same version of the sub vi from the same location)
For ex:  if 2 main VI's A and B use two diferent Vi's that have the same name 'C'
opening B along with A will open the sub vi C which originally is a sub Vi of A instead of intended VI.
But Labview will inform by a pop up msg that this sub vi which was expected to be at location x has been opened from location Y,
Just heed to all those pop up messages and life will become easier.
One final note: while closing a VI,  if save changes msg pops up, do select 'explain changes' and try to ascertain which sub vi has changed before selecting 'save sub VI's' option.
and Finally keeping a cool head is trick 😉
regards,
Dev
(2,663 Views)
