11-11-2010 03:02 AM
i am currently working on a labview. anybody help me how to merg a output data from two independant loops in labview and writing them into a text (lvm) file. one loop output is voltage and other output is current, how to merg these outputs and how to write them in a text file?? help me please..
thank you!!
11-11-2010 03:18 AM
Convert both into string array.Use build array to combine the data.
then use "Array to spreadsheet string" function and file IO functions to write it into text file.
11-11-2010 03:22 AM
I attach what I undestood you required. Hope it helps.
Greetings
Andres
